Activity Forums AJA Video Systems Install I/o
  • Install I/o
    Posted by Rogelio Cordovez on March 17, 2006 at 3:41 pm
    Hi, I have a AJA I/O and I just got a QUAD 2.5 w/4ram. I work on BetacamSP and DVCam. If anyone could help me with the following question: When I downloaded the most recent driver AJA Io v2.1 dated 10_14_2005, there are several folders with drivers to install, the one I think I should install is
    under the folder Io, the IoAnalogNTSC-US.mpkg…is this correct? there is also a folder called “packages” , that has drivers like, “proIODrivers.pkg”, “AnalogNTSC_US.pkg”, “digitialNTSC_US.pkg”
    should I install these ones as well? Please help, anyone with I/o experience.
    Thanks for your help,
    Rogelio
    Rogelio Cordovez replied 20 years, 5 months ago 2 Members · 2 Replies
  • Jeremy Garchow
    March 17, 2006 at 3:55 pm
    Use the install package that you will most likely use (you can also install the other ones later if need be, it’ll just add more easy setups). For your setup, I would install the one you are pointing out, IoAnalogNTSC-US.mpkg. Does your DV deck have SDI? If so then you can either install the Digital US setups or create your own easy setup.
    Jeremy
  • Rogelio Cordovez
    March 17, 2006 at 4:42 pm
