Activity Forums Apple Final Cut Pro Legacy install g tech graid
  • install g tech graid
    Posted by Ralph Bertini on March 15, 2006 at 3:32 pm
    Just received my G-raid and PCI express fw 800 card yesterday. Reading docs to install and I’m looking for a slot config for the g-5. Is there any recommended slot location for the card? I know the “other” edit platform is very particular about what slot is used for secondary cards. I wasn’t sure if there was a similar issue with bus segments, etc. Anyone done this recently?
    Dave Mac replied 20 years, 5 months ago 3 Members · 3 Replies
  • David Roth weiss
    March 15, 2006 at 4:20 pm
    It all depends upon what other cards are installed and where. If slot 4, the upper most slot is available, try it there first.
    DRW
  • Ralph Bertini
    March 15, 2006 at 5:24 pm
    Slots 2, 3 and 4 are available. Slot three is a PCI express X 8 slot, wouldn’t it be better there???
  • Dave Mac
    March 18, 2006 at 10:04 pm
    [creatureteacher] “Slots 2, 3 and 4 are available. Slot three is a PCI express X 8 slot, wouldn’t it be better there???”
    One of the changes from the “old” PowerMac G5s to the new dual-core models is the use of PCI Express slots. With the older G5s, the fastest PCI-X slot was slot 4.
    With the PCIe slots in the newer G5s, the 3rd slot is the “8x” slot (fastest). For more details, check out this document from Apple:
    Dual-core PowerMac G5 Technology Overview
    So, slot 3 would certainly be the fastest slot. I am not sure if there would be any benefit to using this slot for the FW card. I kind of doubt it. If you are not going to use a capture card, go for it. If you will use a capture card in this Mac, it should probably go in slot 3. You’ll have to check the capture card manufacturer for more info on that.
    Best regards,
    Dave
