Activity Forums Compression Techniques Install FFMpeg + x264 + AAC + libavfilter on debian lenny
  • Install FFMpeg + x264 + AAC + libavfilter on debian lenny
    Posted by Lossius Thomas on January 12, 2011 at 11:20 am
    Hello all,
    Sorry for my spelling, I’m French …
    My OS is debian lenny.
    It’s been three days (much more actually) that I have problems with FFmpeg, my goal is to install FFMPEG + x264 + AAC + libavfilter.
    The encoding is done only with the x264 + AAC codecs, but FFMpeg should support many incoming formats.
    5 methods I tried, but none seems to work, I get “Unknown encoding libx264” or “unrecognized option-vf” or make fails.
    I’m stressed out, here is the last procedure I followed:
    cd / home / src
    wget https://freefr.dl.sourceforge.net/project/lame/lame/3.98.4/lame-3.98.4.tar.gz
    tar-xvf lame-3.98.4.tar.gz
    cd lame-3.98.4
    . / Configure
    make
    make install
    cd / home / src
    git clone git: / / git.videolan.org/x264.git
    cd x264
    . / Configure - enable-pic - enable-shared
    make
    make install
    apt-get install libfaad libfaac-dev-tools-dev libgsm libgsm1 libgsm1-dev libvorbis-dev libxvidcore4-dev
    # FFMPEG SVN-r25942
    svn checkout svn: / / svn.ffmpeg.org / soc / libavfilter
    cd libavfilter
    . / Checkout.sh
    cd ffmpeg
    git clone git: / / git.ffmpeg.org / libswscale /
    export LD_LIBRARY_PATH = / usr / local / lib: / usr / lib: / lib
    . / Configure - enable-libx264 - enable-gpl - enable-pthreads - enable-libmp3lame - enable-avfilter - enable-libmp3lame - enable-libvorbis - enable-libxvid - enable-libgsm - enable-postproc - enable-libfaac - enable-pthreads - enable-gpl - enable-x11grab - enable-nonfree - enable-shared - disable-ffplay - disable-ffserver
    ffmpeg-v
    I really hope someone can help me, I’m desperate!
    Lossius Thomas replied 15 years, 7 months ago 2 Members · 2 Replies
  • Michael Rampe
    January 19, 2011 at 9:51 pm
    [Lossius Thomas] “It’s been three days (much more actually) that I have problems with FFmpeg, my goal is to install FFMPEG + x264 + AAC + libavfilter.”
    Not sure about your issues… but:
    Do you really need the SOC libavfilter? A lot of the SOC filters are now present in the trunk and unless there is something specific you need in libavfilter, I would recommend the FFmpeg SVN trunk rather than the version that SOC libavfilter needs/gets.
    Michael
  • Lossius Thomas
    January 20, 2011 at 10:44 am
    thank you for your post but my problem is solved, i’ve found a issue 🙂
