Activity Forums Avid Media Composer Install ERROR Message!
  • Install ERROR Message!
    Posted by Mark Dalzell on January 6, 2009 at 10:57 pm
    Just finished installing Avid Media Composer 3.0. When I try and open
    it I get the following message: “Initializing ACPL Effects”.
    Stays on that page then closes.
    Any ideas would be helpful.
    Mark Dalzell
    PC Specs (if needed)
    VisionDAW 4U 8-Core Xeon Workstation
    2 Intel QUAD-Core Xeon 5365-3.0GHz, 8MB, 1333MHz Processors
    16GB 667MHz Fully Buffered Server Memory Modules (2x2GB)
    Microsoft® Windows® XP Professional x64 Edition
    WDC 250GB, Ultra ATA100, 7200 rpm, 8MG Buffer Main OS HD
    MOTU 24 I/O (main) / MOTU 2408mk3 (slave)
    2 WDC 750GB, SATA II, 7200 rpm, 16MG Buffer HD (Samples)
    Plexor PX-800A 18X Dbl. Layer DVD+/-RW Optical Drive
    Front Panel USB Acess
    Integrated FireWire (1394a) interface
    Thermaltake Toughpower 850W Power Supply
    Dual ESATA Bracket
    2 WWDC 750GB, SATA II, 7200 RPM, 16MB Buffer HD (Raid 0)
    3xUAD1 Universal Audio Cards
    EVGA NVIDIA GeForce 9600GT, 512MB,
    PCI-Express, DUAL-DVI Video Card
    Dual 25.5″ Samsung 2693HM LCD HD Monitors
    Michael Hancock replied 17 years, 8 months ago 2 Members · 3 Replies
  • Michael Hancock
    January 6, 2009 at 11:15 pm
    Windows XP 64-bit is not an approved OS. You need Vista Business 64 bit or 32 bit, or XP 32 bit. XP 64 is a no go.
    Your 9600GT graphics card may also be to blame. Avid prefers Quadro cards, but there are people using the 8800 with success. I believe they soft-mod the card using RivaTuner or something to make it appear as a Quadro.
    Definitely change your OS, though. I’ve never heard of people successfully running Avid on XP64.
    Michael.
  • Mark Dalzell
    January 7, 2009 at 12:04 am
    Michael,
    Thanks for taking time to reply and help out. I will get a third
    removable drive and instal Windows Vista x64 on it as suggested.
    I will also swap out my current card for an FX Quadro 1700.
    Should be good to go then don’t you think?
    Best.
    Mark
  • Michael Hancock
    January 7, 2009 at 12:31 am
    Unless you have a fx1700, start with just the OS. Your graphics card may work fine so there’s no reason to spend money on a new card.
    However, if you have a 1700 available, switch it out too. Otherwise your system looks nice. The biggest issue with Avid’s are the CPU (Intel only), graphics card (nVidia – Quadro preferred), and OS (XP32, Vista Business 32/64).
    Michael.
