Activity Forums Blackmagic Design install Decklink, which slot, MacPro 2010
  • install Decklink, which slot, MacPro 2010
    Posted by Toby Heslop on December 9, 2010 at 10:40 pm
    Is there a preferred slot that a Decklink Extreme 2 card should be installed in a macpro 2010 model?
    the top slot has ‘RAID’ printed on the motherboard.
    Does it matter which slot the card is seated in?
    Toby Heslop replied 15 years, 8 months ago 3 Members · 5 Replies
  • Kristian Lam
    December 10, 2010 at 3:04 am
    Hi
    You can use the 3rd slot.
    regards
    Kristian Lam
    Blackmagic Design
  • Kristian Lam
    Hi
    regards
    Kristian Lam
    Blackmagic Design
  • Toby Heslop
    December 10, 2010 at 3:25 am
    3rd slot from the top or 3rd slot from the bottom?
  • Joshua Helling
    December 13, 2010 at 10:00 pm
    Hehe,
    Good point, I hate the way those are labeled. Slot 3 or 4 will work great. Those are the top two slots. The MacPro’s label from the bottom up. This means Slot 1 is on the bottom (typically your graphics card) and slot 4 is on the top.
    FWIW, when I build rigs in my lab or for use at trade show, I put the Decklink in Slot 4 and the HBA (for the drive controller) in slot 3 and it works a treat every time.
    Hope that helps.
    Sincerely,
    Joshua
    Director of Support
    Blackmagic Design Inc.
  • Toby Heslop
    December 14, 2010 at 8:55 am
    thanks Josh
