Activity › Forums › Zaxwerks › Install 3d invig with AE 6.5
  • Install 3d invig with AE 6.5
    Posted by Ryan925. on June 22, 2006 at 4:47 pm
    I am trying to install 3d Invigorator into AE 6.5, I put it in the right plug in folder but it’s not showing up? How do I install this?
    Jon Okerstrom replied 20 years, 3 months ago 2 Members · 3 Replies
  • Jon Okerstrom
    June 22, 2006 at 5:54 pm
    Ryan,
    The plug-in and associated folders go into AE’s plug-in folder, as you said. Normally, the plug-in and associated folders are contained in a folder called 3D Invig-AfterEffects.
    It’s important that the stuff in that main folder not be moved around. The plug-in will look for certain libraries in certain places. There should be some sort of read me first documentation on the installation process.
    You should quit AE, then install Invig, then relaunch, then you should see it.
    Does this help?
    Jon
  • Ryan925.
    June 23, 2006 at 3:41 pm
    The folder is left as is, it’s in the proper place, but still does not work.
  • Jon Okerstrom
    June 24, 2006 at 12:15 am
    It doesn’t show up under the effects tab>Zaxwerks>3D Invigorator?
    Jon
