Activity Forums Apple Final Cut Pro Inspector Window only shows Spatial Conform selection
  • Inspector Window only shows Spatial Conform selection
    Posted by Michael West on May 2, 2019 at 4:39 pm
    Good morning: I imported footage into FCPX 10.3 (no upgrade because it works and why mess with what works?) and when I went to adjust some things in the Inspector, it only showed the Spatial Conform option. When I reloaded other projects, everything was as it is supposed to be. My first instinct is to just delete the whole import (just 2 cameras and some audio, not a major hassle), but I want to know if anyone else has had this issue and if there is a remedy in case it happens again. Thanks for any help. Michael
    Michael West replied 7 years, 4 months ago 2 Members · 3 Replies
  • Michael Hancock
    May 2, 2019 at 9:07 pm
    Do you have more than one file selected in the browser window? If you do, you’ll only have Spatial Conform in the inspector.
    Michael Hancock
    Editor
  • Michael West
    May 2, 2019 at 9:24 pm
    Thanks for the reply.
    Nope, I click on one at a time.
    Michael
  • Michael West
    May 3, 2019 at 4:04 pm
    Thanks for getting back to me, Michael:
    I created a multicam clip and it solved the problem.
    The inspector contained all the options.
    I will finish the project, then go back and reload everything to see if the problem gets resurrected.
    Michael West
