Activity Forums Adobe After Effects Expressions inspecting the type of key interpolation
  • inspecting the type of key interpolation
    Posted by Nick Hill on September 23, 2010 at 2:22 pm
    Just wanted to check, there’s no way in expressions to determine the type of a specified key, is there?
    For example:
    // Designed to go in a sourceText property as a debugger
    p = transform.position;
    n = 0;
    if (p.numKeys > 0) {
    n = p.nearestKey(time).index;
    if (time < p.key(n).time ) {
    // key n is ahead of us
    n--;
    if (p.numKeys > n && n > 0) {
    // there's at least one key after this one, and we're not before the first key
    q = p.key(n).typeOf;
    if (q == 'linear') {
    // do something
    if (q == 'bezier') {
    // do something else
    } else {
    // outside the current range of keys
    Kevin Camp replied 15 years, 11 months ago 4 Members · 5 Replies
  • Dan Ebberts
    September 23, 2010 at 2:44 pm
    I don’t know of any way to do that.
    Dan
  • Nick Hill
    September 23, 2010 at 2:48 pm
    In that case, I doubt there is!
    Cheers 🙂
  • Chris Wright
    September 23, 2010 at 8:42 pm
    valueAtTime would know what’s going on on each key right?
    https://technicolorsoftware.hostzi.com/
  • Kevin Camp
    September 23, 2010 at 9:02 pm
    and you could use the difference of valueAtTime and valueAtTime on frame prior compared to the difference of valueAtTime for key1 and key2 divided by the frames separating those keys to determine if the interpolation was linear or not…
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Kevin Camp
    September 28, 2010 at 9:23 pm
    i actually just had the need to do this, and what i used was:
    if (speedAtTime(key(2).time)==0){
    // it’s soft interpolation
    }else{
    // it’s hard interpolation
    obviously, key(2) could be whatever key you needed to look at. and i assume it would work for velocityAtTime() also…
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
