Activity Forums Apple Final Cut Pro Legacy insert/overwrite problem on Bella keyboard
  • insert/overwrite problem on Bella keyboard
    Posted by Steven Austin on March 21, 2012 at 1:33 am
    I have the Bella pro 3.0 FCP keyboard. The yellow/red insert & overwrite keys (at the top) don’t function. I contacted Bella but have not heard back. Does anyone have the manual or a solution? Thanks!!!
    Jerry Hofmann replied 14 years, 6 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    March 21, 2012 at 1:52 pm
    You need to disable some of the system’s keyboard commands in order for those insert and overwrite buttons to work at all. It’s not a problem with the keyboard. Open your Mac’s system settings (found in the apple menu in the finder) and then click on the keyboard settings. Turn off all of the F keys to not be used by the system. Then the F keys in FCP will operate as advertised.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
