Activity › Forums › Apple Final Cut Pro Legacy › Inserting to Master
  • Inserting to Master
    Posted by David Barrett on May 6, 2007 at 11:47 pm
    I am trying to insert a segement back into a master.
    I have marked in/out points, chosen “in to out” in the “Mastering Settings”
    The segment duration is 8 sec 9 frames but FCP says
    “the deck may be unable to perform this operation since
    the edit duration is only one frame”
    I am using Mac Pro 2 x Dual Core Xeon 2.66GHz,
    Blackmagic DeckLink HD Extreme (PCI-e Version)
    editing to Digibeta DVW A500P.
    Any thoughts ?
    Regards,
    David Barrett
    Famous by Tuesday
    Melbourne Australia
    Ben Holmes replied 19 years, 4 months ago 5 Members · 6 Replies
  • Stuart Ferreyra
    May 7, 2007 at 12:38 am
    Trash the FCP’s preferences and POA Cache.
    Relaunch FCP and give it a try…
    Stuart Ferreyra
    Timecode Multimedia
    President
    Santa Monica, CA 90025
    https://www.timecodemultimedia.com
  • Nick Meyers
    May 7, 2007 at 12:40 am
    “in to out” in Mastering settings is not what you want.
    go to the main, “video” page,
    at the top, change “mastering” to “Editing”
    set in and out points in the edit to tape window,
    and an in point in your source sequence.
    load sequence into viewer,
    then drag to “insert” in ETT window.
    should work.
    cheers,
    nick
    (Sydney, Aust)
  • David Barrett
    May 7, 2007 at 1:48 am
    Thanks for the quick reply Stuart and Nick.
    I trashed the preferences, then followed Nick’s instructions….
    now the digibeta cues, pre rolls, goes into record…but
    for only 1 or two frames. Does this make any sense ?
    Regards,
    David Barrett
    Famous by Tuesday
    Melbourne Australia
  • David Barrett
    May 7, 2007 at 1:52 am
    I changed the in point (to the previous shot)
    and now it works ! Thanks guys.
    Regards,
    David Barrett
    Famous by Tuesday
    Melbourne Australia
  • Michael Gissing
    May 7, 2007 at 3:44 am
    Insert won’t work if you have marked an in or out point during a transition like a dissolve. Also if the points are in a gap between clips, insert slug. The insert needs to be marked in and out on clips.
    Strangely FCP tells you the edit can only be one frame, but it really indicates that the in/ out points aren’t valid.
  • Ben Holmes
    May 7, 2007 at 9:54 am
    You’re not going mad – I’ve had this ‘bug’ on numerous occasions. Changing the edit point was the only solution on occasions.
    Ben
    Editec Broadcast Editing Ltd
    EVS & FCP specialists for live broadcast.
    OB Server 1 HD – Mobile FCP editing done right.
