Activity Forums Adobe Premiere Pro inserting silence in the audio track
  • inserting silence in the audio track
    Posted by Bodybuildingbs on October 28, 2005 at 12:58 am
    Hello
    I have set up my audio tracks following the advice given to me in this forum…thank you.
    But I have a question..Track One is for dialog…well some scenes have no dialog so should I insert silence in the track or does premiere pro read nothing on the track as silence…and would I have to do this on all tracks?
    Thank you.
    David Goodwin replied 13 years, 4 months ago 4 Members · 5 Replies
  • Scott
    October 28, 2005 at 2:57 am
    There is no need to insert silence. Premiere interprets nothing a silence. Only put audio in where you need it.
    Scott
  • Scott
    October 28, 2005 at 2:58 am
    …nothing AS silence…
    Sorry.
  • Bodybuildingbs
    October 28, 2005 at 8:05 pm
    Thank you that saves me a lot of work.
  • Craig Howard
    October 30, 2005 at 7:31 am
    What would you have used for silence and how would you have made it if you had to insert “silence” ?
    How would you have known if it was in synch or even if it was actually where you placed it in the timeline ?
    BTW: A “silent” clip has the same filesize as a “noisy” clip.
  • David Goodwin
    May 15, 2013 at 10:07 am
    Sorry to intrude into this discussion but is there a way of adding a short silent clip like I can add blank black clips? I want to use it as a kind of spacer for using with Ripple Delete. It’s like a digital video version of a bookend to keep a space open between books/clips. Thanks
