Activity Forums Adobe Premiere Pro inserting clips in a looong sequence?
  • inserting clips in a looong sequence?
    Posted by Gabi Bucataru on December 13, 2014 at 4:46 am
    Hi Gang!
    I am curious to know if you have an elegant way of inserting clips in a loong sequence that contains several layer of video/audio, and what not.
    I find it pretty cumbersome to zoom out to be able to select all the clips to where I need to insert the gap for the new clip, then to drag the bunch back to close the gap.
    Something tells me that there’s an easy way. Curious to know how would you go about.
    thanks!
    gabster
    Jeff Pulera replied 11 years, 9 months ago 4 Members · 3 Replies
  • Tero Ahlfors
    December 13, 2014 at 5:14 pm
  • Jorn Bergmans
    December 15, 2014 at 10:53 am
    As the link Tero posted reads, holding the Command key while dragging a clip onto your timeline will insert that clip and move all clips over to the end of your newly inserted clip.
    You will see a visual representation in the form of markers along a bar stretching along all of your video and audio tracks
  • Jeff Pulera
    December 15, 2014 at 2:42 pm
    On a PC, you would hold the CTRL key while dragging footage to the timeline
    Jeff Pulera
    Safe Harbor Computers
