inserting audio clips and closing gaps in Multitrack Editor
In ProTools, it’s possible to insert an audio clip at a particular location in a track and the clips behind the inserted one will automatically shift over so that the clip can “fit”. Is this possible in Audition? Or do I need to move all my clips to the right first to make room for the clip that I want to insert?
Also, when I use Ripple delete to close the gaps between edited clips, the clips move around and I have to move them again so that they’re not out of order. What am I doing wrong here?
Thank you!
