Activity Forums Boris FX inserting an image into a Credit Roll
  • inserting an image into a Credit Roll
    Posted by Tonia Galasso on May 28, 2008 at 2:48 pm
    Hi everybody
    I hope this is the right forum
    I need to insert an image into a final credit roll in FCP using Boris plugin
    Anyone could help me please?
    thanks
    tonia
    Peter Mcauley replied 18 years, 4 months ago 2 Members · 1 Reply
  • Peter Mcauley
    May 28, 2008 at 4:21 pm
    If you are using Graffiti or RED to perform the credit roll then you need to drop the image (or clip) into the title container and it will appear at the end of the title. If you want it to appear somewhere between the start and finish of the title and are using a single page of imported or generated text, then duplicate the text page, edit the text in both pages so that one has the text before the image and the other has the text for after the image, and then set the tracks in the container so that they are start text, image, end text.
    If the text is already set in FCP and you want to leave it there and just insert the image, then you could blade the credit roll where you want to insert the image, insert a slug where you made the razor cut, apply FX or RED to the slug, import the image into FX / RED, and return to the FCP timeline.
    I hope this helps.
    Peter.
