Activity Forums Maxon Cinema 4D Inserting a spot light perpendicular to a selected polygon surface
  • Inserting a spot light perpendicular to a selected polygon surface
    Posted by Miem Chan on March 12, 2006 at 1:41 pm
    Is there a quick and easy way to insert a spot light somehow automatically allign itself to perpendicular orientation to the select polygon surface and illuminates that surface?
    If the that polygon rotates, then light rotates to keep its 90 degree angle to the polygon surface.
    Björn Marl replied 20 years, 5 months ago 2 Members · 1 Reply
  • Björn Marl
    March 12, 2006 at 2:46 pm
    You can solve this with a bit of Xpresso using the polygon node, the normal output for the polygon and the vector2HPB node.
    Cheers
    Bj
