Activity Forums VEGAS Pro inserted text media blurred
  • inserted text media blurred
    Posted by Gino Salerno on July 6, 2009 at 6:59 pm
    I am using Vegas Pro 9.0 (64-bit). I have all the latest in video cards and enough memory. I have a 15 minute video rendering in HDV. Everything renders fine except the titles, which look blurry. I have tried the interlace, the master-track, deleting all effects. I have tried the titles on their own track and the titles on the same track as the video. When the whole thing is rendered, the video is super sharp but the titles on the inserted text media are blurry. Also, I am using Arial font, which I have always used in the past with no problems. Please help with blurry text.
    Gino Salerno replied 17 years, 2 months ago 2 Members · 2 Replies
  • Owen Myers
    July 7, 2009 at 2:03 am
    I have had an issue with blurry credit text and generated text. My solution there was to adjust the format for the generated text/credit to 1440 by 1080 to match my project resolution. It came out crystal clear. Right click over text and either dig into the properties or it may be in “Edit Generated Media”. Change the resolution so that everything matches your project or just use the highest reslotuion possible.
    I had the same issue. I have a rediculous rendering computer and it caused me to scratch my head. Bottom line, it’s not how great your computer is, it’s how high your Generated Text reolution is set for.
  • Gino Salerno
    July 14, 2009 at 4:20 pm
    Yes, it worked. Thanks.
    However, if there are several parts where text is inserted, it has to be done every single time. Do you know if there is a setting for all text to come as 1440 X 1080 instead of adjusting that every time?
