Activity Forums Adobe After Effects Expressions insert variable into string
  • insert variable into string
    Posted by Bryan Woods on September 25, 2015 at 7:59 pm
    I’m using a script to insert an expression into a layer’s position property. How do I add variables into the expression thats being set?
    for example, lets say:
    var theLayer = “Some Layer Name”;
    and the position property of the selected layer my script is adding an expression to is:
    myLayer.property(“position”).expression = “thisComp.layer(\”theLayer\”).position;
    How do I get “theyLayer” variable’s value to be inserted into the expression? I can’t figure it out. In python its as easy as %s, then defining your variables after the quotes of the string in order as they appear. But here, I’m not sure.
    Patrick Grossien replied 9 years, 6 months ago 3 Members · 6 Replies
  • Dan Ebberts
    September 25, 2015 at 8:09 pm
    This should work:
    myLayer.property(“position”).expression = ‘thisComp.layer(“‘ + theLayer + ‘”).position;’;
    Note the use of single quotes to get the double quotes into the expression.
    Dan
  • Bryan Woods
    September 25, 2015 at 8:43 pm
    Yup, that did the trick. Although my example wasn’t entirely accurate, I needed to add .toString() to my variable to get it to work properly, but I got it working! Glad to see you’re still hanging around here Dan! Always appreciative of your help. Its been a while since I’ve needed to script in AE again; a little rusty.
    Actually, one quick followup:
    How would you insert a large chunk of expression but keep it readable in my script editor? At the moment, I have to crush all of the expression code I’m inserting into one very long line. Is there some operator, like \n to do a line break, but not affect the actual expression being inserted?
    Thanks again!
  • Dan Ebberts
    September 25, 2015 at 8:52 pm
    Mine usually end up looking like this:
    var theExpr = 'x = 100;\r' +
    'y = 100;\r' +
    'z = 100;\r' +
    '[x,y,z]';
    var theLayer = app.project.activeItem.layer(1);
    theLayer.property("Position").expression = theExpr;
    Dan
  • Patrick Grossien
    February 11, 2017 at 3:25 pm
    Hi Dan,
    I’m facing a similar problem. I’m trying to reference the name of a parent composition via a text layer source text in a pre-comp (in order to grab values of controllers in that parent comp).
    Any idea if and how I might get this to work?
    parentComp = '"'+thisComp.layer("Name_Parent_Comp").text.sourceText+'"';
    freq= comp(parentComp).layer("Glitch Controller").effect("RGB glitch FREQUENCY")("Slider");
    amp= comp(parentComp).layer("Glitch Controller").effect("RGB glitch AMPLITUDE")("Slider");
  • Dan Ebberts
    February 11, 2017 at 4:11 pm
    I think this is all you need to do:
    parentComp = thisComp.layer(“Name_Parent_Comp”).text.sourceText.value;
    Dan
  • Patrick Grossien
    February 22, 2017 at 4:26 pm
    YES! Thanks Dan!
    parentComp = thisComp.layer("Name_Parent_Comp").text.sourceText.value;
    freq= comp(parentComp).layer("Control_Layer").effect("frequency")("Slider");
