Activity Forums Adobe Premiere Pro Insert stop working properly
  • Insert stop working properly
    Posted by Suzin Daly on November 6, 2016 at 1:07 pm
    I am using Premiere Pro CS6…I consider myself a beginner
    I have never had a problem with using insert icon to insert clips on the timeline. It has worked wonderfully. For reasons I don’t know and I don’t know if I changed anything.. but now if I use the insert icon the clips insert at the very beginning of the timeline.
    I tried using using the track selection tool to move clips down to make space to bring in clip. It did not select all the clip on all the timelines – I had a disaster, all went out of sync, for some reason clips got deleted [without my deleting] I spent a long time rebuilding, re-syncing so where there is a lot of ADR, I have grouped together.
    I feel like I have this huge mess, not sure what I did to create this problem, which makes it hard to correct. I don’t know how clear my question is – if there are any suggestions I would be so appreciated.
    Best Suzin
    Suzin Daly replied 9 years, 10 months ago 2 Members · 4 Replies
  • Ann Bens
    November 6, 2016 at 1:24 pm
    Make sure you have the correct track selected and source patched.
    Adobe Certified Expert Premiere Pro CS6/CC
    Adobe Community Professional
  • Suzin Daly
    November 6, 2016 at 1:41 pm
    I’m sorry I not sure I understand track selected source patched.
    For insert – the cursor is where I would want the clip inserted, when I click on the insert icon the clip goes to the beginning of the timeline.
    In trying to make a space I did a tutorial where I learned about the track selection tool. I was so happy to have thought problem solved…
    For the track selection tool, the main track moved down beautifully, I did not realize that only the main track and audio moved down, none of the lower audio tracks and the one video track above did not. I did not realize that right away.
    I am wondering now, like in Vegas 13 when you use the track selection tool, you have to also click on all track, markers and
    regions somewhere, so all move down.
  • Ann Bens
    November 6, 2016 at 2:10 pm
    https://helpx.adobe.com/premiere-pro/using/source-patching-track-targetting.html
  • Suzin Daly
    November 6, 2016 at 2:31 pm
    Thank you for taking the time for the tutorial.
    Looks like another option for inserting and will try to take advantage.
    I am still curious why using the insert icon does not work properly when having in/out points from the source monitor. Will only insert to the beginning of the timeline. What is throwing me off, I been inserting this way for almost a year without a problem.
