Activity › Forums › Adobe Premiere Pro › Insert question
Insert question
Posted by Randy Johnson on September 1, 2010 at 12:57 amAnother noob question. How do you insert a clip in the time line? I can do it from the source window but not from another clip in the time line. It keeps over wrighting the clip.
Randy Johnson
Rando1968@comcast.netRandy Johnson replied 16 years ago 4 Members · 6 Replies -
Todd Kopriva
September 1, 2010 at 6:31 amInsert a clip into a sequence”
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Ann Bens
September 1, 2010 at 8:27 pmRightclick on the clip in the timeline and select Reveal in Project.
Clip is now selected in the Project Window. Double click on this clip in the Project Window and it will open a fresh in the Source Monitor. Trim and ad to timeline.
In short: if you want more instances from one clip you need to open it from the Project Window. -
Randy Johnson
September 1, 2010 at 10:22 pmThanks guys for the info. Dont mean to complain but doesnt it seem like kind of a rounda bout way to do it? I mean if I have clips already in the time line that is. Well I can make this work thanks again.
Randy Johnson
Rando1968@comcast.net -
Ann Bens
September 2, 2010 at 10:26 pmNo its not if you think it through.
If you double click on a clip in the timeline it opens in the Source Monitor. If you change in and out point of that clip in the Source monitor you also change the in and outpoint in the timeline.
If you want two sections of the same clip in the timeline you open from the Project Window and not the timeline. -
Jeff Pulera
September 4, 2010 at 1:50 pmHi Randy,
Hold the CTRL key down, and while holding it, grab the clip you want (whether from bin or another place in timeline) and drag it to the timeline spot where you want it, then release mouse. Clip will be placed at current position, and clips to the right will Ripple (move over to accommodate).
NOTE: On left of timeline, where you have VIDEO 1, VIDEO 2, AUDIO 1, AUDIO 2 – make sure none are highlighted, or only the highlighted tracks will shift, this throws everything out of sync! If this happens, just CTRL-Z to UNDO, then try again.
Jeff Pulera
Safe Harbor -
Randy Johnson
September 5, 2010 at 3:44 amThanks for all the tips I havent edited on Premiere since V 6.5. Your right its not that bad and im getting very comfortable with Premiere CS5. I do have one issue/question though, I was editing a job I inserted some video from a clip no problem LATER in the project I wanted to take some other footage from that same clip but every time I tried the video inserted to the original part of the time line not where the cursor is now. Is that correct? or is there a setting I need to change? Bug?
Randy Johnson
