Activity Forums Apple Final Cut Pro Legacy Insert into the timeline
  • Insert into the timeline
    Posted by Joseph Mclachlan on July 27, 2006 at 3:38 am
    Hello,
    I was wondering if there was a way to easily add a stiil shot to the timeline and insert the image between two existing still shots that are joinded by a transition.
    I have approximately 100 pictures in an elaborate slide show. I wanted to add more pictures after my last edit. The Transitions are causing problems by cutting images short when I delete them. Is there a more direct method? or do I need to select all the images after the point I’d like to add, and move them all manually and reinsert the transitions adjusting the length of each picture to the original length.
    Hope this makes sense
    Joseph
    Joseph Mclachlan replied 20 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
