Activity Forums Apple Final Cut Pro Legacy Insert edits over-running…
  • Insert edits over-running…
    Posted by Michael Lansdell on February 18, 2008 at 11:39 am
    Another week, another issue with Final Cut! My system has started over-running when I perform an insert edit. By this I mean that it starts in the right place, but runs past the end point set by the out marker and writes black over what follows. It over-runs by about 5 seconds.
    Any ideas? I’m having to replay out entire programmes due to a single shot change, not good!
    Thank you for your time,
    Michael
    Jeremy Garchow replied 18 years, 7 months ago 6 Members · 10 Replies
  • 10 Replies
  • Jerry Hofmann
    February 18, 2008 at 1:56 pm
    What are you using as a device control setting with which deck?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Michael Lansdell
    February 18, 2008 at 2:07 pm
    My deck is a DVW-500P, I’m using a Blackmagic Decklink Extreme (6.6.2 Driver) and the Device Controller setting is Blackmagic PAL 25Hz.
    Thank you!
  • Walter Biscardi
    February 18, 2008 at 2:15 pm
    [Michael Lansdell] “Another week, another issue with Final Cut! My system has started over-running when I perform an insert edit. By this I mean that it starts in the right place, but runs past the end point set by the out marker and writes black over what follows. It over-runs by about 5 seconds.”
    This exact issue started happening to me this week with a Panasonic AJ-HD1400 DVCPro HD deck. Thought it was something wrong with the deck, but maybe we have another bug in 6.0.2.
    My solution was to insert edit from that shot to the break. Be sure to fill out a feedback form for Apple on their website.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR
    The new Color Training DVD now available from the Creative Cow!
    Read my Blog!
  • Kim Rowley
    February 18, 2008 at 3:02 pm
    Hi Michael…
    That happened to me and it was because I had ticked the “black trailer” option in the Mastering settings. I hadn’t thought of it before since I was just inserting from in to out points, but for some reason enabling that trailer option mattered even when I wasn’t inserting “entire media”.
    You’ve probably checked that already but since it got me once…
    Dual 2.7 GHz G5, 4GB RAM, ATI Radeon 9650, Xserve RAID, AJA IO, 2 20″ Cinema Display, FCP Studio 2 (6.02), OS X10.4.11
  • Jerry Hofmann
    February 18, 2008 at 3:30 pm
    Device control is firewire? If so you’ll never get a truly accurate instert to tape… if it’s RS-422 then it should be frame accurate.
    Jerry
  • Walter Biscardi
    February 18, 2008 at 3:33 pm
    [Kim Rowley] “You’ve probably checked that already but since it got me once…”
    I’m using the “Editing” function and still have that issue.
    Read my Blog!
  • Luke Price
    February 18, 2008 at 4:54 pm
    I had this issue in ‘Editing’ mode this week too.
    We were using an AJA KONA card and RS-422 remote through SDI to a SD DigiBeta deck. It was on a clients kit so don’t have the chance of checking settings now. (I will forward a link to this thread though)
    We had 2 suites and ‘Edit 1’ was working fine and dropping edits without this problem but we had to do a rush output from ‘Edit 2’ had a few seconds of black added to the insert. Odd.
    Luke
    Mac Pro Quad 3GHz, 4GB RAM, 2x7TB XServe RAID
  • Michael Lansdell
    February 18, 2008 at 5:15 pm
    It turns out I had a five second trail on after my inserts, just like Kim Rowley said, I guess this was reset by the 6.6.2 update for blackmagic.
    Thank you all yet again, much appreciated!
    Michael
  • Walter Biscardi
    February 18, 2008 at 5:19 pm
    Not here. I even just brought up the Edit to Tape function. It’s in Edit and even if I was in Mastering, everything is unchecked as I don’t use anything from the Mastering settings.
    Read my Blog!
  • Jeremy Garchow
    February 18, 2008 at 5:41 pm
    [walter biscardi] “It’s in Edit and even if I was in Mastering, everything is unchecked as I don’t use anything from the Mastering settings.”
    Have you tried Mastering setting though, making sure it’s all unchecked, but keep the “Print: in to out” setting?
