Activity Forums Apple Final Cut Pro Legacy Insert editing into a Dolby-E master?
  • Insert editing into a Dolby-E master?
    Posted by Dan Hodlick on June 7, 2012 at 4:33 pm
    Hi all – we have an HDCam master show coming from the network that has stereo l/r on 1 & 2, and Dolby-E on 3 & 4. They want us to insert segments into the program, much like a commercial insert. These inserts will be stereo.
    I know FCP can ingest Dolby-e, but would cutting it and inserting something in the breaks destroy the encoding?
    Mark Spano replied 14 years, 3 months ago 4 Members · 4 Replies
  • Joseph Owens
    June 7, 2012 at 9:58 pm
    NO. Dolby-E is “burst” encoded so you can insert /assemble edit on tape. The frame rate must agree, obviously.
    jPo
    You mean “Old Ben”? Ben Kenobi?
  • Michael Gissing
    June 7, 2012 at 10:56 pm
    The caveat is that you must insert a Dolby E stream or else the surround audio just drops out with the inserts. You can’t insert PCM audio onto those tracks.
    Also you will not get any level control or crossfades at the insert points.
  • Joseph Owens
    June 9, 2012 at 2:43 pm
    [Dan Hodlick] ” These inserts will be stereo.”
    Ah, I missed that. Yes you can only insert Non-Audio into a Non-Audio channel. Dolby E, although it can be any number of channels internally, is editable, but can’t be mixed and matched with non-encoded media.
    jPo
  • Mark Spano
    June 12, 2012 at 1:56 pm
    ALSO
    make sure your deck is set to CUT and not XFADE for audio editing. You can’t crossfade a Dolby E stream.
