Activity Forums Apple Final Cut Pro Legacy Insert Edit on Closed Caption
  • Insert Edit on Closed Caption
    Posted by Jason Griffith on January 23, 2007 at 3:55 pm
    Hey there. I need to to do an insert edit on a Dvc pro tape with Closed caption. I’m using final cut pro 5.04 on a Panasonic AJ-sd930 DVCPro deck. 2 questions. Does anyone know if this will wipe out the existing Closed caption on the tape and will it overwrite the audio? I’m using DVCPro50
    Jason Griffith
    Broadcast Editor
    The Active Word
    “An Unexamined Life Is Not Worth Living” – Socrates
    Jason Griffith replied 19 years, 7 months ago 2 Members · 2 Replies
  • Joe Paolo
    January 23, 2007 at 4:09 pm
    It will erase the captioning for the duration of the edit. If you don’t select audio on your insert settings it won’t record on the audio channels.
    joe
    joe
  • Jason Griffith
    January 23, 2007 at 5:04 pm
