Activity Forums Apple Final Cut Pro insert edit in FCP X
  • insert edit in FCP X
    Posted by Dan Crouch on January 21, 2013 at 2:00 pm
    Sorry to post more simple questions, but I can’t find how to insert edit a clip. As in cmd c a clip or section of my edit and insert edit it in another part of the sequence. In FCP 7 it was SHIFT V.
    The other question is, is it possible to make template’s of effects, as in Favorite effects in FCP 7.
    I have a simple dissolve I would like to repeat and can’t find a way of saving it to use again.
    Any help would be gratefully received,
    Dan.
    Bret Williams replied 13 years, 7 months ago 3 Members · 5 Replies
  • Jeremy Garchow
    January 21, 2013 at 3:55 pm
    [dan crouch] “Sorry to post more simple questions, but I can’t find how to insert edit a clip. As in cmd c a clip or section of my edit and insert edit it in another part of the sequence. In FCP 7 it was SHIFT V.”
    Simply paste, command-v, in the primary. If you are using connected clips, you’ll have to move them in to the primary first, or copy and paste the parent clips as well.
    [dan crouch] “The other question is, is it possible to make template’s of effects, as in Favorite effects in FCP 7.
    I have a simple dissolve I would like to repeat and can’t find a way of saving it to use again.”
    Unfortunately, only some transitions can modified in Motion to be used as a Motion Templates. Which one are you using?
    Jeremy
  • Bret Williams
    January 21, 2013 at 4:26 pm
    On the other hand, you can do pretty cool stuff like highlighting all the dissolves in the timeline inspector, and change all their durations at once with ctrl+d and typing a duration. But yeah, favorites still needs reimplentation.
  • Dan Crouch
    January 21, 2013 at 7:25 pm
    Thanks very much for the post’s.
    So a simple paste is an insert edit, that’s great, Ty.
    The effect I was trying to save as a favorite was a simple dissolve. Oh well, maybe next update?
    That does sound handy you can change all effects at once, very cool, maybe that’s the workaround?
    Thanks for the help,
    Dan.
  • Jeremy Garchow
    January 21, 2013 at 9:08 pm
    [dan crouch] “The effect I was trying to save as a favorite was a simple dissolve. Oh well, maybe next update?
    You can set any dissolve to be the “default”. You add the default transition by pressing command-t.
    What you can’t set is duration.
  • Bret Williams
    January 22, 2013 at 4:50 am
    I can see how a lack of favorites or the ability to save bins of fx or transitions in a project would upset some. I very rarely made favorites as it seemed they were just getting trashed all the time with driver updates from matrox. I would use the same effect by option dragging it from one spot in the timeline to the other. Still works in X thankfully.
