Activity Forums Avid Media Composer Insert Edit Export function
  • Insert Edit Export function
    Posted by Marcus Taylor on June 3, 2025 at 1:35 pm
    Insert Edit Export function:
    I have an exported MXF OP1a file, and I want to make small changes to the stereo audio track. Media composer has a function which allows an already exported MXF OP1a file to be updated as long as the original timeline is the same length as the exported file. It looks like you can’t change or add time to the exported file but limited to solely replacing small amounts of picture, audio, or both.
    However, I have not been able to do this. Has anyone been successful with this function and what ground rules lead to this working?
    Any thoughts much appreciated,
    M
    Glenn Sakatch replied 1 year, 1 month ago 3 Members · 3 Replies
    June 5, 2025 at 5:28 pm
    Hey Marcus,
    I am still new to the latest version of AVID (we are talking 15 years+ since I last worked on AVID).
    However, I know of standalone software that allows you to edit in wrappers such as MXF, but didn’t know that AVID did it.
    Found this short tutorial that may be of help to you:
    https://youtu.be/-2M8Gv8Y8lo?si=W1xQ93pQ9mdlJCsq
    It is 4 years old, but have a list of formats that was supported back then.
  • Marcus Taylor
    June 20, 2025 at 5:50 pm
    This is a useful YT video, and explained well – but we have discovered that it doesn’t work well with audio. I start with multiple audio tracks, that are mixed down to stereo mixdown tracks for LP playback. That is stable for our features. But fixing small sections and dropping them in, does not work. So no answers so far.
  • Glenn Sakatch
    July 19, 2025 at 2:45 am
    I’ve never had success with Avid’s insert methid. Other than paying a lot of money for the cinetools software, I find it much easier to just re-export. I do have a free program that will insert into a prores file, and I will use it in a pinch,but it takes less than the time for a cup of coffee to export a half hour broadcast show…not worth the cost for the other software. Unless I’m sitting on location, where the truck is waiting for a feed…I still have to upload the file, so the immediacy is usually not there in my world to justify the cost
