Activity Forums Apple Final Cut Pro Legacy insert chapter markers during capture?
  • insert chapter markers during capture?
    Posted by Jack Nastowski on May 15, 2007 at 11:59 pm
    I will be recording about 30 interviews, all with about 15 of the same exact questions.
    I’ll have a laptop set up capturing the interviews in to Final Cut. Is there a way to insert markers during capture?
    Are there any programs out there that will capture quicktime movies and add FCP chapter markers during capture?
    Bill Lee replied 19 years, 3 months ago 3 Members · 3 Replies
  • Bill Lee
    May 16, 2007 at 2:51 am
    Live Capture Plus 2.0 US$49
    https://www.squarebox.co.uk/lcplus.html
    I haven’t used this software myself, but the company has been around a few years. They have a downloadable demo version, limited to five minute captures so you can try-before-buying.
    From their website, new in version 2.0:
    “New keyboard shortcuts to make it easier to enter log notes and mark events while a capture is in progress”
    Bill Lee
  • 13 Create COW Profile Image
    13
    May 16, 2007 at 6:05 am
    You cannot add chapter markers during capture. It must be done later.
    I looked at the website listed in the previous post and did not see anything about adding chapter markers during capture.
  • Bill Lee
    May 16, 2007 at 9:00 am
    Apologies to all.
    Yes you are right, you can’t add FCP-recognised Chapter markers during a capture with Live Capture Plus 2 (LCP2).
    The statement from their website: “mark clips and events while a capture is in progress.” only puts a timecode into the notes field when you press Command-T “Insert Timecode Marker” and then allows you to type anything after that. You can put multiple timecode markers in this notes field. If you export the captured file as XML, it doesn’t make these ‘marker’s into real markers, but puts them in your clips notes field as one concatenated string. Obviously it would have been nice to have these exported as markers and then imported into FCP as markers, but Live Capture Plus can’t do that right now. I’ve just suggested it to the developers as feedback.
    zrb123’s posting prompted me to download the demo software and have a closer look at it and markers in FCP.
    The XML file exported from FCP for a clip with markers generates a definition inside the <clip> and </clip> pairs, for example – a marker at ten frames in from the beginning of the clip with a duration of 4 frames:
