Activity › Forums › DaVinci Resolve › Input transform doesn’t stick?
  • Input transform doesn’t stick?
    Posted by Roman Hankewycz on November 10, 2011 at 3:46 pm
    Hey guys,
    I’ve got a project with a lot of archival footage where I’ve needed to adjust the aspect, size and position to compensate for various sources. Throughout the project I’ve come up with 3 basic input transform presets that I apply to clips then I used the pan, tilt, and other commands to nudge the clips into the right aspect, size and position.
    I’ve found that as I’ve progressed through the project something happened with the stability of the input transform presets. When I open a session a lot of my clips default to preset “None.” They maintain the specific changes I made to the pan, tilt, zoom, etc, sliders but I need to set the input transform preset over and over again for many clips. Anyone experience this? Is this a glitch? Is there a specific order that you have to follow to have the settings stick?
    Thank you
    roman hankewycz
    harbor film company // colorist
    Roman Hankewycz replied 14 years, 10 months ago 2 Members · 2 Replies
  • Barrie Williams
    November 11, 2011 at 9:21 am
    This is a known bug.
    It just doesn’t work yet.
    Barrie
  • Roman Hankewycz
    November 14, 2011 at 1:42 am
    OK.
    Does anyone know of a work around? It seems that my input transform settings worked well for a while and then started acting up as the project progressed. I’ve tried setting the presets in the the conform page instead of the format page and it seems to be better although I can’t figure out why some clips stay properly transformed and why others revert back to their default.
    Any input?
    roman hankewycz
