Activity › Forums › Sony Cameras › “INPUT SOURCE NOT GOOD” error
  • “INPUT SOURCE NOT GOOD” error
    Posted by Jamie Herring on July 26, 2016 at 11:29 pm
    I edited video from FCP X and exported via Catalyst Browse as an .MXF.
    Once saved to disc in the clip folder, I am unable to import that clip from XDCAM Transfer, Import error message reads: “Error reading metadata from file ‘P Fit to Fight_1.MXF’ (input stream is not good())
    I am transitioning from FCP 7 to FCP X. All clips saved from FCP 7 import fine, but nothing saved from FCP X will import.
    Only difference between clips is the clip exported from FCP X has Frame Rate 59.94p(59.94p), instead of Frame Rate 59.94p
    Jamie Herring replied 10 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
