Activity › Forums › Adobe After Effects › Input problem
  • Input problem
    Posted by Marti Davies on July 14, 2008 at 4:29 pm
    AE CS3 PRO. Out put settings, quick time mov’format animation,depth,millions of colors plus.color premultiplied. Ok render is fine alpha chanel fine. Problem is when I try and import the same file back into AE. Crash!…The same file works ok in Prem pro and other apps,including quick time player?…..Any ideas!..
    Marti Davies replied 18 years, 2 months ago 2 Members · 5 Replies
  • Chris Wright
    July 14, 2008 at 5:52 pm
    millions of colors plus you meant millions of colors+ right?
    not
    millions of colors. the later doesn’t support alpha. AE is very picky. and if you try a different codec output, bets are AE will work again. The animation codec is very buggy if you try to output a complex project with it. Try a different lossless codec for a small render and see if that fixes it.
  • Marti Davies
    July 14, 2008 at 6:47 pm
    Thanks for the help Chris. None of the quick time formats worked.
    I have used windows now. It works fine!…Thanks again.
  • Chris Wright
    July 14, 2008 at 8:47 pm
    its not really the export as it is the corrupt interpretation AE gets when you try to import the rendered animation file back into AE. That’s why you probably haven’t seen it crash much. AE’s render and import code don’t always 100% match. ie.(crash).
  • Chris Wright
    July 14, 2008 at 10:13 pm
    “AE’s render and import code don’t always 100% match. ”
    I made a lazy answer. I should have said, AE’s dll files still have to interpret the quicktime codecs and if the quicktime files are corrupted, AE will fail to open them, but other players still might because they’re not as sensitive to errors.
    it might be interesting to ask the first poster, marti davies, if he’s using pc instead of mac. It could very well be that macs with animation codec are more stable than pc’s. I’m not a programmer but I can say this, would it be in the better interest of Apple to make a more stable quicktime for Mac instead of PC? lol.
    btw. thx for virus tip :O
  • Marti Davies
    July 15, 2008 at 7:38 am
    Yes I have a PC!…
