Activity Forums Apple Final Cut Pro Legacy input commands from keyboard
  • input commands from keyboard
    Posted by Ruy Fajardo on September 11, 2010 at 9:12 pm
    Hi dudes, is there a way to assign some keyboard strikes to make some special moves that are not set in FCP?
    for example i want to create an script or something like that in order to make a 1 sec advance with a single key touch instead shift arrow.
    that would be nice to keep timeline in center all the time and when one pushes space bar, the entire sequence moves forward keeping the timeline there.
    there are some moves that could no be assigned using the custom keyboard layout, is there a way to change this using some programming?
    regards KB
    Ruy Fajardo replied 16 years ago 2 Members · 2 Replies
  • Jerry Hofmann
    September 13, 2010 at 11:14 am
    FCP isn’t scriptable I’m afraid… The timeline window doesn’t scroll either, which has been a long asked for feature. FWIW, when Avid added this feature, it blew up a lot of code for whatever reason. Took them 6 months to sort it out in fact. You can only change the keyboard commands with the Keyboard customize layout window, but you can do quite a bit there.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    DVD:https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Ruy Fajardo
    September 15, 2010 at 1:44 am
    Hi thanks, its a shame, i asked because somewhere i heard about FCP scripting.
    regards
    KB
