Activity Forums Adobe Premiere Pro In/Out Points
  • In/Out Points
    Posted by David Smooth on August 21, 2015 at 10:40 am
    Is it possible to see how many In/Out points you’ve made on a clip in the Source/Preview window?
    e.g. I have a clip and I want to extract two separate parts from that clip but I also want both those parts to be highlighted if I come back to the clip a week later.
    I suppose as a work around I could just mark every In/Out point manually but I’m curious if there’s an automated function
    Cheers!
    Alex Udell replied 11 years, 1 month ago 2 Members · 1 Reply
  • Alex Udell
    August 21, 2015 at 1:30 pm
    Hi David…
    Make subclips from the master.
    Mark your in/out then hit cmd(or ctrl on pc) U.
    sub clips use the same under lying media but are soft limited to the in and points you set. you can however disable the soft limits and get back to the full clip extents again.
    But that way you can mark as many i/o from a master clip as you want…just label them accordingly and you should be good.
    Alex Udell
    Editing, Motion Graphics, and Visual FX
