Activity Forums Avid Media Composer In/Out points for multiple master clips in Media Composer
  • In/Out points for multiple master clips in Media Composer
    Posted by Will Fiennes on February 19, 2015 at 3:45 pm
    Bare with me this is a strange one I know….
    So I have a Gopro Timelapse made up of around 3000 jpegs.
    It appears that during filming some stills have become corrupt and they will not build into a timelapse in either Quicktime Pro or MpegStream Clip or indeed Avid.
    So my idea was to import the stills into Avid and it would let me know which files are dodgy and in fact just let me skip right over them. On import I restricted the import length to 1 second because that is the minimum. I thought it might then be possible to apply a 1 frame i/o into all clips and then build a sequence using the alt drag and drop method. This could then be exported as a QT
    However I cannot find a way to do it. I can of course apply an i/o manually but this is not practical. I have read of a method using the script view but can not get that to work.
    Is there any way of either setting i/o points for multiple clips, or for one and then copying that metadata onto the remaining 2999!
    Hope that makes sense and thanks for any help
    W
    Edit Assistant/Assistant Editor/Film maker
    Shane Ross replied 11 years, 6 months ago 2 Members · 1 Reply
  • Shane Ross
    February 19, 2015 at 9:22 pm
    Have you tried the GoPro Studio app for making a QT clip of of these?
    Shane
    Little Frog Post
