Activity › Forums › Adobe After Effects › ink effect
ink effect
Posted by Damani on July 22, 2005 at 2:59 pmhello all,
I have a question I am trying to simulate ink spreading or growing but I don’t know exactly the best approach, the example I am trying to do is here @…https://www.shilodesign.com/HBO def poetry. Thanking all in advance
damani006
Lazlo Hollyfeld replied 21 years, 2 months ago 4 Members · 7 Replies -
Damani
July 22, 2005 at 3:52 pmhmmm…thats odd try this line http://www.d-kitchen go to work then advertising and watch “Jade Empire” the end clip has the ink effects I was talking about
damani006
Steve Roberts
July 22, 2005 at 4:01 pmInk effects are usually practical (shot), and this one looks to me as if it were shot.
Steve
Damani
July 22, 2005 at 4:25 pmyeah thats what I figured so what I am going to do is use some ink vectors from illustrator and use a gradient wipe with some cloud tank effects to cheat it, but thanks for your input I just wanted to know if there was a cheat in AE beside what I am doing.
damani006
Lazlo Hollyfeld
July 22, 2005 at 6:32 pmI made a number videos a few years ago that uses ink as a mask for effects. Once you shoot it, the sky is the limit. Check out the following link for still images:
https://www.lionleon.com/intersection/
Kieran
July 22, 2005 at 8:25 pmI’m shooting ink in water at the moment.. Do you have any useful tips and hints?
So far I’ve discovered the joys of a catheter and the differences between using cold ink/warm water and warm ink/cold water..
thanks
kieran -
Lazlo Hollyfeld
July 22, 2005 at 9:39 pmUse a very clean tank / glass, but try to minimize reflections. Shoot at high frame rates if possible in order to see the true beauty unfold, then you can speed it up as much as you want later on.
Arie
