Activity › Forums › Adobe After Effects › Ink Bleed fade in???
Posted by Michael Dominic on March 19, 2016 at 2:03 pmMy client wants the Uncle Sam: I Want You poster to fade up as if the ink is bleeding through the paper.
I have tried both methods below, but they look fake. I need it to look as real as possible.
Can anyone share a technique to achieve what I need to?
https://www.youtube.com/watch?v=U6eAZVCkQvM
https://www.youtube.com/watch?v=iHicEwnffgs
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Fredrik Åkerlund replied 10 years, 5 months ago 3 Members · 8 Replies -
Michael Szalapski
March 19, 2016 at 9:00 pmEither spend more time then they did on refining your mattes or film actual black ink bleeding through actual paper and use that as a matte.
– The Great Szalam
(The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Michael Dominic
March 19, 2016 at 9:11 pmI have several different ink movie files. The problem is it looks like the image is appearing through clouds more than an ink bleed,
How would you refine the mattes?
I haven’t seen any example where this looks good.
Michael Szalapski
March 19, 2016 at 9:38 pmWhat you have are ink tank effects. You would need stock footage of ink actually bleeding through paper. And you’ll need an old/handmade paper to really get the look you want. Modern paper is too clean and fine.
You would need to add a lot more complexity to the mattes. You would want several different effects in play too.
– The Great Szalam
Michael Dominic
March 19, 2016 at 9:40 pmThats one of the issues. The poster background is clean and has to be so.
Michael Szalapski
March 19, 2016 at 9:50 pmThe background can be clean, but you probably don’t want your ink bleeds to be very clean.
– The Great Szalam
Michael Dominic
March 20, 2016 at 12:13 pmI’m not relying on magic. I have several real ink bleating on paper videos. The problem is that there feels like a disconnect between the ink and image.
Michael Szalapski
March 23, 2016 at 5:04 pmHave different ink bleeds bring in different sections of the image. Check out the credits from Sherlock. Each image is cut up into several pieces and different bits of ink are revealing each piece.
Also, consider using different ink shots layered on top of each other to work together on revealing each section. Like, one brings in a 15% opacity version and the next brings it to 46%, and a third in bleed brings it to 100%, etc.
– The Great Szalam
Fredrik Åkerlund
March 23, 2016 at 11:26 pmI belive the problem is that revealing the whole image in one “ink bleed” is just so unrealistic so the human eye can´t really make sense of what´s going on. Never having done any ink bleeds I had to try and at best I made a pretty cool film burn effect. Cool but not what we´re after. 🙂 To make it belivable I think you have to start out in a way that says to the eye “Hello, this is an ink bleed” and build it up to the full reveal. I made a quick and dirty proof of concept video just trying out my idea:
I separated the over all main colors of the poster (blue, skin, white, red), revealed them one at a time and then finished off with the complete picture. Now, keep in mind that this is just 30 minutes work and the same ink matte used over and over again but I think the idea is worth trying out.
