Activity › Forums › Adobe After Effects › ink alpha fades
ink alpha fades
Posted by Rafa Calleja on January 6, 2007 at 10:18 pmhi im planning to solve the transitions between locations in a music video that im shooting, in postproduction. A good example of what i want to do is this clip of jesse maccartney https://www.youtube.com/watch?v=PxP1tXJsP68 i don
Rafa Calleja replied 19 years, 8 months ago 3 Members · 5 Replies -
Mylenium
January 6, 2007 at 11:12 pmThey look pretty syynthetic to me – animated masks with the Roughen Edges effect on top of them. Should work for you as well, though personally I’d probably prefer shooting some real ink blots.
Mylenium
[Pour Myl
Rafa Calleja
January 6, 2007 at 11:26 pmmylenium cheers for ur answer… would u animate the expansion of the mask with the roughen edges above or keyframe the change of the mask shape using smart mask interpolation….do u think this will give a smooth feeling??? well the example from youtube is quite bad quality but guess that the full quality result is quite smooth, don
Mylenium
January 7, 2007 at 11:52 am[rafa calleja] “mylenium cheers for ur answer… would u animate the expansion of the mask with the roughen edges above or keyframe the change of the mask shape using smart mask interpolation….do u think this will give a smooth feeling??? well the example from youtube is quite bad quality but guess that the full quality result is quite smooth, don
Julian Sixx
January 7, 2007 at 3:14 pmHi
i would take advantage of the power of Gradient Wipe.
Create in Photoshop a white gradient matte.Create a new layer and fill it with black. Next, select the brush tool (B). Set your brush color to white+opacity to 30 and choose a grungy type brush tip.
Start painting with your grunge brush,solid black areas of the transition layer will show first, white will show last.
