Activity › Forums › Avid Media Composer › ingesting video into Avid
Posted by Lor Porter on February 21, 2014 at 7:25 pmOriginal video shot on Sony camera with some kind of card (trying to get specifics now). I have MP4 files that when I try to import are not supported. I have to convert them over to mov files.. First is that ok… second am I losing quality? Third – is there an easier way?? I’ve downloaded the sxs driver I was told I needed… and I am not sure what to do next.
Any help you could offer is greatly appreciated!
Lori I’m running MC 3.5Lor Porter replied 12 years, 7 months ago 4 Members · 11 Replies -
Richard Sanchez
February 21, 2014 at 8:01 pmDo you just have the MP4 files? You need the whole card structure in order to properly bring in that footage if it came from an SxS card.
Also, since you’re on MC 3.5. You really should consider upgrading, since the AMA features of MC 4 and above will make this footage much easier to bring in and transcode.
This link describes a method of bringing the footage in without AMA, since you don’t have it on version 3.5
https://blog.davidesp.com/archives/278
Richard Sanchez
Los Angeles, CA“We are the facilitators of our own creative evolution.” – Bill Hicks
Lor Porter
February 21, 2014 at 8:20 pmHi Richard – I do have all the information… it’s all things in each clip folder – I have the mp4, SMI, PPN, XML and BIM.
I know about upgrading… I just don’t have the funds right now…
BUT – it’s not from an XD cam – I have no problems using the AMA with XD cam – I use that all the time. I do have it that feature.
Michael Phillips
February 21, 2014 at 9:01 pmDoes Resolve Lite play the files? If so, you can transcode to native MXF wrapped DNxHD and take it from there.
Michael
Richard Sanchez
February 21, 2014 at 9:50 pmYou mentioned cards and the SxS driver. That sounds like XDCAM EX, which usually comes from an EX1 or EX3 camera (As opposed to the XDCAM Optical Discs) Is this correct?
Richard Sanchez
Lor Porter
February 21, 2014 at 11:25 pmYes Richard, Sorry – I got confused. It’s the XDCAM-EX intraframe codec.PMW-EX1, the PMW-EX3 – yes.
Michael Phillips
February 22, 2014 at 12:35 amYou may also be able to use the Sony Content Browser software and rewrap as MXF if needed.
https://pro.sony.com/bbsc/ssr/micro-xdcam/resource.downloads.bbsccms-assets-micro-xdcam-downloads-XDCAMSoftwareDownload.shtml#appsMichael
Brendan Charles
February 24, 2014 at 5:18 pmMPEG Streamclip has yielded pretty good results when converting MP4 files for me. You could try converting to .MOV with the Animation codec, or ProResHQ for minimal loss of quality. The files will be much larger, but at least you will have an easier time ingesting them into AVID and with not much loss of quality.
Lor Porter
February 24, 2014 at 5:42 pmThank you Brendan,
I converted them all to mov clips – in movavi converter. I just don’t know if it “chaged” the video – since I’m not sure what the original looked like. I took FOREVER to bring into the avid (there is a lot of video) – but the ingest was a little over 24 hours.
I just downloaded MPEG Stream clip – just in case I need to go back and do that for the producer.
Thanks everyone for your help!
Lori -
Brendan Charles
February 24, 2014 at 5:55 pmNot sure what your workflow is like- but in the future couldn’t you just AMA link the clip, then transcode your sequence so you really only import/transode only what you use of that file, instead of importing the whole thing.
