Activity › Forums › Adobe Premiere Pro › Ingesting Video But No Audio
  • Ingesting Video But No Audio
    Posted by Mark Welch on February 26, 2012 at 12:27 am
    Starting third project with Premier/CS5.
    I’m ingesting AVCHD MTS files from my hardrive but most of the clips do not play the audio associated with them. This never happened on my previous projects.
    Audio is on the original MTS files because I used Quicktime Player to preview them before starting the project.
    Not sure what might be going on here.
    Running CS5 Production premium on an iMac/OS 10.6
    Cornell Williams replied 14 years, 4 months ago 4 Members · 3 Replies
  • Paul Neumann
    February 26, 2012 at 4:29 am
    Can you see the waveforms? If so, load a clip in the timeline and send the audio off to Audition (render and replace operation) and see if you can hear it there. That’s where I’d start.
  • Jeff Pulera
    February 26, 2012 at 2:47 pm
    Hi Mark,
    With AVCHD, or any tapeless format, the best practice is to copy the entire folder structure from memory card to hard drive – do not pick just the video files. Then in Premiere, use Media Browser pane to import clips.
    Hope this helps
    Jeff Pulera
    Safe Harbor Computers
  • Cornell Williams
    May 14, 2012 at 2:42 pm
    Hey check out my tutorial just follow my steps and it should fix your audio import problems whether it only imports 30 seconds or doesnt import audio at all. https://www.youtube.com/watch?v=5onhwmz79qc&list=UUnjGjZkouBpxO2ToeN_VeKg&index=3&feature=plcp
