Activity Forums Apple Final Cut Pro Legacy Ingesting from a HD deck. What about the audio?
  • Ingesting from a HD deck. What about the audio?
    Posted by Antony Tsoukatos on July 8, 2010 at 2:37 pm
    Hello all
    Could anyone please brief me up of how HD ingest can take place with FCP?We want to ingest HD tapes, coming from a HD Deck in FCP. And what I am trying to confirm is this:
    1.Is the audio from the HD Deck embedded through the SDI output?
    2. If the audio is Dolby Encoded, will it be ingested as such?
    3. If the answer to 2 is yes, how would I be able without the use of a DAW to decode the audio and perform minor edits?
    4.And last – but not least 🙂 – what would be the best way to re-encode for the final edited file?
    Gary Adcock replied 16 years, 2 months ago 4 Members · 9 Replies
  • 9 Replies
  • Jeremy Garchow
    July 8, 2010 at 2:53 pm
    What deck?
  • Antony Tsoukatos
    July 8, 2010 at 3:18 pm
    Good question. Not in yet. Could you lay down for me what difference would this make?
  • Steve Eisen
    July 8, 2010 at 3:46 pm
    If indeed your HD deck has SDI, your audio will be embedded.
    You also need to have a capture card/IO device.
    If you have HDV tapes, it’s a totally different workflow.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Jeremy Garchow
    July 8, 2010 at 3:49 pm
    There’s too many to mention, but most likely it will be embedded audio. Do you have a capture card? I would hope that the deck will decode the dolby as FCP won’t handle it too well.
    Jeremy
  • Antony Tsoukatos
    July 8, 2010 at 4:08 pm
    I am sorry I did not clarify the technical backgound.
    It is definitely going to be HD Deck with an SDI output. And a Kona card is going to be used for the ingesting. What I am trying to clear out is how the editing process of with all encoded/ decoded audio (refer to my initial posting if you can please)
    Thanks for your help all
  • Jeremy Garchow
    July 8, 2010 at 4:09 pm
    And read my previous post about Dolby.
  • Antony Tsoukatos
    July 8, 2010 at 5:00 pm
    Thanks for all your help Jeremy…
    So, you say that the deck might decode the audio for you. But that “might” can worth a lot of money, avoiding the purchase if kit that does decode it :)…
    If it does not, what happens then? As I am writing this I am thinking that the only other solution could be to feed the audio out of the HD deck to a Dolby encoder and feed the audio out of the Dolby Decoder to the Kona card upon ingesting. Would that be the best workaround?
  • Jeremy Garchow
    July 8, 2010 at 5:02 pm
    [Antonis Tsoukatos] “Would that be the best workaround? “
    Definitely the cheapest. I’d do it from the deck to ensure a/v sync. if you think you will be working with DOlby a lot it’s best to just buy it on the deck. you will use it all the time.
  • Gary Adcock
    July 8, 2010 at 5:20 pm
    [Antonis Tsoukatos] “2. If the audio is Dolby Encoded, will it be ingested as such? “
    the Kona/ FCP workflow does not support Dolby encoded audio.
    Dolby is a proprietary audio format and requires Dolby hardware to handle correctly.
    gary adcock
    Studio37
    Post and Production Workflow Consultant
    Production and Post Stereographer
    Technology Development
    Quality Assurance Assistance
    Chicago, IL
    https://blogs.creativecow.net/24640
