Activity › Forums › Apple Final Cut Pro Legacy › Ingesting 5d stills as time-lapse clip
  • Ingesting 5d stills as time-lapse clip
    Posted by Daniel Schultz on December 10, 2010 at 10:37 am
    I’m renting a 5d for the weekend and I’m hoping to get some cityscape time lapse b-roll for a piece I’m working on. In other forums, I got advice on how to use an intervelometer to capture stills. But then I don’t know how to ingest the stills into either motion or FCP to create 24 fps. Does anyone know how to do this? I don’t have after effects. I’m posting in the Motion forum as well.
    Many thanks
    Dan S.
    Gary Askham replied 15 years, 9 months ago 4 Members · 4 Replies
  • Andrew Rendell
    December 10, 2010 at 10:48 am
    Set the Still/Freeze Duration in the User Preferences to 1 (or whatever you want each frame to last) then import the folder with the stills in into FCP. Open that folder in the browser and make sure that the stills are in number order, then select all and drop them onto a timeline. Then go for a coffee while it renders.
  • Daniel Schultz
    December 10, 2010 at 11:26 am
    thank you!
    Dan S.
  • Jason Brown
    December 10, 2010 at 11:37 am
    You could also “open as image sequence” in QuickTime 7…and transcode to ur favorite codec from there.
  • Gary Askham
    December 10, 2010 at 12:48 pm
    I’d go with the Quicktime route. It has been designed for dealing with Image Sequences.
    Bringing a few hundred images into Final Cut Pro is a sure-fire way to bring it to it’s knees.
    FCP and Avid Technical Support
    Air Post Production
    Shoreditch – London
