Activity Forums Apple Final Cut Pro Legacy ingest growing files from Sony disk recorder
  • ingest growing files from Sony disk recorder
    Posted by Frank Steffenhagen on October 15, 2009 at 2:35 pm
    Hi everyone,
    I wonder if anybody has done any ingesting of growing files
    from a Sony disk recorder (DSR-DR1000AP). This could either be
    via re-wrapping the file or accessing the disk recorders
    hardware from within FCP.
    Important is that the file has not got a fixed file size with
    an in/out, it’s a live recorded track that grows over time
    and should be accessed as such within FCP. The problem I have
    is that we use FileZilla (connected via Ethernet) which gets
    the file into the computer. From there you can import the file
    in FCP, once you load it into the player window it stops updating
    itself.
    A theory could be that this is a DV stream, which does not have
    a header that tells the software to keep the file growing over
    time.
    My question: is there any re-wrapping software that can deal with
    growing file sizes? I heard about MovieRecorder from Softron and
    Quick Time reference files and was wondering, if anybody has dealt
    with it.
    Thanks for your time. Cheers
    Frank
    Frank Steffenhagen replied 16 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
