Informal Survey: Where is your project file in relation to your media & assets?
Hive mind question: where do you save your project file vs. the media and assets for your Premiere projects? All on the same drive? Project on a different drive than media?
(Researching the cause for some recent crashes & I suspect the old workflow we’ve been using – all on 1 drive – may be causing problems. Over the years I’ve done both without noticeable impacts – except when using FCP7. My recent switch back to Windows has me curious if things need to change.)
Ben Howard + buttonpusher.tv + twitter: buttonpusher
Editing – Consulting – Workflow – Asset Management
