Activity Forums Apple Final Cut Pro Legacy Info abt usb voice over recording
  • Info abt usb voice over recording
    Posted by Jas Sekhon on October 11, 2007 at 11:10 am
    HI can anybody suggest me a gud usb microphone to record vo’s in small parts …i tried mobile pre usb from m audio but its not giving me the quality i expected… i m using imac 2.4 ghz dualcore intel. I tried to do the recording from the VO utility from final cut pro(version 5.1.4)the waveform is very small and its giving me glitches….do i need to record on some other software…..or is there any better usb combination…..i need to do a lot of vo’s in small parts and its not convenient to hire a recording studio or artist most of the times….
    Jas Sekhon replied 18 years, 11 months ago 4 Members · 4 Replies
  • Bouncing Account needs new email address
    October 11, 2007 at 11:29 am
    The Mobile Pre USB should work fine.
    What kind of MIC are you using?
    Does the mic require an internal battery for power?
    Regardless, you can simply use your camcorder (mic plugged into the camera) connected via FireWire and record “live” through the camcorder,
    or
    RECORD the voice-tracks onto TAPE in the camcorder, then capture the tracks to FCP.
    The latter method gives you a recorded tape with timecode to put on the shelf for future capture, if needed.
  • Walter Biscardi
    October 11, 2007 at 11:36 am
    Blue Snowball. Approx. $99 though I would also suggest a pop filter.
    http://www.musiciansfriend.com
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Rafael Amador
    October 11, 2007 at 11:57 am
    You don’t need any software. Just plug the mic to the USB conexion of your Mac and open the QT player. Set the Recording preferences and In the menu File select New Audio Recorder.
    Rafael
  • Jas Sekhon
    October 11, 2007 at 2:35 pm
    Hi… thanx all for ur valuable inputs before ur inputs i really never had too many ideas in my head but creative cow is simply amazing ……
    I now have options right before me and now i think i will take my time and go for a best combination…
    THANX EVERYBODY N CHEERS……
    JAS.
