Activity Forums Adobe After Effects Info about video card Nvidia core Cuda for After Effect CS6
  • Info about video card Nvidia core Cuda for After Effect CS6
    Posted by Mar Lev on September 1, 2013 at 3:07 pm
    hello to all,
    I need your help about a station for my video editing so configured:
    cpu intel quad core q9550
    8gb ram ddr2
    matherboard asus p5q pro
    samsung 256gb ssd 840
    video nvidia geforce gt9800 cart
    more ‘various hard disk sata for the data.
    sw the video editing I use are edius 6.0.7 and sony vegas pro 12.
    Unfortunately, since I installed windows 8 edius does not work anymore ‘
    now I want to use on my pc to make video editing Lightworks 1.11.1 free with remarkable performance, and the sw da vinci for color correction.
    while for composing I would use adobe after effects cs6.
    after effect is that da Vinci used a lot and the gpu core cuda.
    I would like to hear from you if for my use and ‘better off buying a picture k600 or card type nvida geforce gtx?
    I ask you experts especially to have a nvidia card fully compatible with after effect on the speech of CUDA cores.
    unfortunately I can not spend as much, and I ask you what ‘s the best video card that I can take as value for’ price?
    already ‘that there are, I ask you the model and brand of some laptops with intel i7 cpu 8gb ram and nvidia video card to buy with a good quality’ money?
    wait for your answer.
    thank you very much
    sorry about my bad english
    mark
    Ian Mapleson replied 13 years ago 3 Members · 4 Replies
  • Mar Lev
    September 1, 2013 at 3:48 pm
    sorry i have changed a little my post
    hi my name is marco
    sorry about my bad english i see your page internet the specialist of technology and video editing advanced
    i hope you help my about :
    my video editing station configuration is :
    8gb ram ddr2
    video nvidia geforce gt9800 512 mb ddr3 pci express 2.0
    power supply atx 600 watt
    i use this sw video editing edius 6.0.7 and sony vegas pro 12.
    I would like to upgrade my video card too old
    i have important question
    I ask that the video card that I recommend us, both electrically compatible with my motherboard and see standard pci express 2.0
    and release that you can insert without major physical obstacles,
    and you can feed with my power supply atx 600 watt
    thank you very much
    marco
  • Todd Kopriva
    September 1, 2013 at 4:35 pm
    See this page for information about hardware for After Effects: https://adobe.ly/pRYOuk
    There are some links from that page to some benchmark test results for the GPU acceleration of the ray-traced 3D renderer (the only thing in After Effects that uses CUDA).
    Be sure to read this carefully, so that you know how the GPU matters (and, importantly, how it does not matter) for After Effects:
    https://blogs.adobe.com/aftereffects/2012/05/gpu-cuda-opengl-features-in-after-effects-cs6.html
    After Effects team blog
  • Mar Lev
    September 3, 2013 at 5:08 am
    info about video card nvidia and model of laptop for video editing for use with lightworks and after effect cs6
    which video card NVIDIA CUDA cores advise me to work with after effect?
    hi my name is marco
    8gb ram ddr2
    assuring me that any good Nvidia GPU will be compatible with the Mercury Playback engine.
    GTX (xxx) Ti with Cuda vs. HD 6850 or similar with OpenCL ??
    thank you very much
    marco
    Hi Marco,
    With your system a GTX650Ti Boost or at GTX660 would be the best card for your system.
    Also, you should add more RAM. Take it up to 16 gig for After Effects.
    Best Regards,
    Dave
    Studio X Productions
    hello dave,
    thank you very much for answer me.
    I wanted to ask an opinion on the GTX 670, which does not cost much more than ‘the gtx660.
    do you think that the 670 video card and ‘compatible with my motherboard and how overall performance of video editing
    those programs using graphics and video can use Open GL and instructions cuda?
    possibly in the not too distant future I could upgrade my pc
    see:
    motherboard
    cpu intel quad core
    ram. 16 gb or more ddr3 1600 mhz
    since you’re so kind could you tell me some model and brand of laptop to do video editing with the best ratio
    quality ‘money?
    thank you very much
    bye marco
  • Ian Mapleson
    September 3, 2013 at 11:32 pm
    Marco writes:
    > geforce gtx?
    I suppose it depends on what you can afford. Personally I would recommend
    a platform upgrade since at this level of performance you’re going to be
    hitting bottlenecks with RAM capacity/speed, and the CPU.
    I’d recommend a Quadro card for the primary display (more reliable,
    better viewport performance, precision, etc.) and a separate card (or
    cards) for CUDA. My 3930K setup has a Quadro 4000 and three GTX 580s.
    If you can only use one card though, then a GTX 580 is the best option.
    I make no assumptions as to space issues in your system though.
    Best card for CUDA is the GTX 580. Get a 3GB model if you can, but even a
    1.5GB model is a far better option for CUDA than any of the 600 series.
    Indeed, the 580 can beat the 700s most of the time for CUDA. They’re
    quite cheap too now, especially 2nd-hand. I’ve bought ten of them in
    recent weeks, four of them being 3GB versions.
    > release that you can insert without major physical obstacles, and
    Ah, again we have more possible bottlenecks. A 580 is a large card, and
    personally I’d want a better PSU than a 600W no matter what newer card
    one used. My own rule for powerful cards is: 750W+ for one card, 1kW+ for
    2 cards (though for lesser cards these are fine for running 2 or 3
    respectively, and I’ve run three 580s with a 1kW PSU before, on a 5GHz
    2700K system).
    Definitely a GTX 580. Get a used one. Your PSU bothers me though. Q9550
    isn’t exactly light on the power usage.
    I’d never use a laptop for this kind of work. Waste of money IMO.
    Overall though, I’m not sure upgrading a platform that old is so wise.
    Your CPU, etc. won’t really be able to get the most out of a good card
    like a GTX 580, especially if it’s limited by having so little RAM.
    Lots of RAM for AE is essential.
    Honestly? Save up, replace the system. Get a used Z68 board, max the
    RAM to 32GB DDR3/1600 or 1866, move over the SSD, better PSU, GTX 580
    for gfx, used 2500K is good value. Much better idea IMO than trying to
    squeeze more out of your old platform.
    Feel free to email/PM me, I can give you specific examples of the items
    I’ve obtained, etc.
    Hope this helps!
    Ian.
    PS. By ‘best’ card for CUDA I did of course mean from your point of view
    with respect to value, etc. In absolute terms the best is a Tesla, or
    a Titan with a display output, but that’s a whole different league of
    pricing pain. :}
    PPS. Sorry I couldn’t reply earlier! I’ve been on holiday for the past
    2 weeks. 😀
