Activity › Forums › VEGAS Pro › Inflated Burn
  • Inflated Burn
    Posted by Denise Nakasony on June 19, 2011 at 12:16 am
    I edited about an hour and a half of material that I had input from a DVD. When I burned the project to disc it would no longer fit on one disc. Nothing I tried would shrink the material from 6.35 GB.
    Everything else worked pretty well and the 30 day free trial has run out, and I need to know if there is a solution to this problem.
    Nigel O’neill replied 15 years, 3 months ago 3 Members · 2 Replies
  • Danny Hays
    June 19, 2011 at 4:11 am
    Click custom and lower the bitrate until it’ll fit on a 4.7 DVD.
  • Nigel O’neill
    June 20, 2011 at 3:03 am
    Denise
    Search the forum for “mark’s bit rate calculator” and you will see a number of posts relating on how to use it, plus where do download it. To get best quality, I would suggest 2 pass variable bit rendering, but the settings to use depend on your source material duration, audio quality etc.
    Another option would be to import your render output into DVDA and get it to fit to disc, but it will force a re-render, and you will lose quality. I would suggest rendering once only (in Vegas)
    My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 10 (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
