Activity Forums Adobe After Effects Infinite White BG Question…
  • Infinite White BG Question…
    Posted by Gerry Cast on October 19, 2017 at 2:37 pm
    Hi. I’m shooting a narrator against a 9 ft. wide, pure white background, and if I don’t turn the XF100 sideways, I can’t get the full body shot, head to toe. But when I do turn the camera sideways to fix that, in post I don’t have enough white on each side as I can see the light stands. To add white to the sides, my idea was to insert a video track using a color matte, use the eyedropper to try to sample the white, draw a mask around the subject and then feather the mask. It “sort of” looks ok, but the white doesn’t exactly match if you look very closely. I’m wondering if I’m doing this correctly or if there’s a better way. Thanks.
    Gerry Cast replied 8 years, 10 months ago 2 Members · 3 Replies
  • Johnny H
    October 19, 2017 at 2:54 pm
    I would shoot a “plate” and use that to fill the other sides. Flip them on both sides so the same edge is matching the middle shot with the person. To make a “plate” basically shoot the same scene without the person and nothing else. Just the white background.
    John Hudson
    Bright Light Visual Communications
  • Gerry Cast
    October 20, 2017 at 4:01 pm
    Thanks Johnny. I’ll try that. Great!
  • Gerry Cast
    October 20, 2017 at 4:04 pm
    Thanks Dave, yes, locked down and not auto-iris. Wow, this sounds great and I can’t believe that I didn’t think of it. I’ll try it and let you all know. Sorry, I didn’t have a screen shot because the studio is in a different location from my home and I haven’t been there. Thanks again.
