Activity Forums Adobe After Effects Infinite Road
  • Infinite Road
    Posted by Sam Pipes on October 6, 2009 at 12:44 pm
    More a “What If” than a practical question. suppose I made a small loop of a section of road with white lines zipping by, say using the Offset on a dashed stroke, and made it so they lined up so it looked like the road was continuing if the little section was tiled. Is there any way to use code or an effect to say “duplicate this X number of times in Y direction” to create the effect of the road running off into the distance?
    Sam Pipes replied 16 years, 11 months ago 2 Members · 2 Replies
  • Mark Walczak
    October 6, 2009 at 3:22 pm
    You may want to play around with the Motion Tile effect. I use it almost weekly, and believe there is an offset effect (that can be used once you precomp your road tile…
    Hope this helps!
    What makes you explode?
    http://www.explosivegraffix.com
  • Sam Pipes
    October 7, 2009 at 2:07 pm
    I ended up getting the effect I wanted with CC_RepeTile, actually, but MotionTile works too! Thanks!
