Activity › Forums › Adobe After Effects › Infinite pan in Motion?
Posted by Phil Williams on July 17, 2008 at 9:22 pmHi guys,
If I have a single frame of a seamless texture, how can I create an infinite pan over it in Motion?
Stephen Smith replied 17 years, 10 months ago 2 Members · 4 Replies -
Stephen Smith
July 18, 2008 at 2:29 pmDo you just want the texture to look like it is panning forever or is there something else in the scene?
Stephen Smith
Lone Peak ProducitonsCheck out my DVD Money Making Graphics & Effects for Final Cut Studio 2
Phil Williams
July 18, 2008 at 6:08 pmThere will be other elements in 3D space in front of the texture. I want to use it as a transitional effect, giving the impression of the camera dollying off at 100mph for a couple of seconds, with the texture background whizzing past, before slowing down again as new foreground elements come into view.
Phil Williams
July 18, 2008 at 6:23 pmThanks Dave, I’ll give that a try.
FWIW, I’m told that the Offset function in AfterEffects is a one-step route to infinite pan, as long as you’re working with a seamless texture. As the pixels scroll off the edge of the screen, they automatically wrap back around on the other side.
Stephen Smith
July 18, 2008 at 6:50 pmPhil,
Based on what you described I would use the replicator on your texture to quickly and easily create a bunch of them. Place the texture next to your shot you want to transition into and then do a camera move. That way the camera move will be seamless from your texture to your subject matter. Hope this helps.Stephen Smith
