Activity › Forums › Maxon Cinema 4D › Infinite Hallway Lighting Approach (Refs Attached)
  • Infinite Hallway Lighting Approach (Refs Attached)
    Posted by Jay Ingles on December 15, 2011 at 8:19 pm
    I’m struggling with how to achieve a light source that feels like the references attached.
    Keys to it:
    – Large moody overhead Light source
    – drops off to black shadows in corners/floor
    – can be cloned/duplicated without odd patterns on walls (for faux infinite hallway)
    Most of my problems related to not being able to get the shadows to fall off where needed. Inverse Square (physically accurate) fall off helps but what i really want to do is add a Flag (on set term) or shape that obstructs the light to create a shadow but is invisible to camera so the sky/horrizon is still visible
    I’ve tried LOTS of attempts with all types of lights but area lights make the most sense.
    Is there a way to use a plane (length of hallway) to emit light/shadows but have it invisible to camera?
    Thanks so much in advance
    any insight is appreciated!
    Example of Scene Built in C4D R13 (attached):
    Project File:
    3416_lighting1.zip
    Brian Jones replied 14 years, 9 months ago 2 Members · 3 Replies
  • Brian Jones
    December 16, 2011 at 1:40 am
    to not see the shadow maker add a Compositing tag to your shadow creating plane and uncheck Seen By Camera
  • Jay Ingles
    December 17, 2011 at 12:17 am
    Thanks Brian, I understand that part of the process but where i’m getting stuck is the lighting rig approach using GI (or not).
    I’m used to real world lighting on set, but can’t get desirable results with GI or area lights and have been trying for 3 full days.
    Any suggestions on how to achieve such a simple, atmospheric look?
    THanks
    Latest Progress:
    3424_lighting7b.zip
  • Brian Jones
    December 17, 2011 at 2:21 am
    the first one doesn’t look much different than a light with Visibility set to volumetric (here is a gross simplification)
    The second looks like it might have a light up top with another light with just visibility (no shadows) pointing upward through the floor to get that ‘cone going upward’ look
