Activity Forums Adobe After Effects Infinite “ground”
  • Infinite “ground”
    Posted by Colin Peterson on October 21, 2014 at 10:14 pm
    I’m trying to have a ball ‘roll’ down a hill for an infinite amount of time, I have the ball rolling and rotating on the ground, and I’ve used Motion Tile on the ground to stretch it. But to create the idea of motion, I need to move the ground backwards, and eventually I run out of ground layer, because Motion tile won’t continue on forever. What should I be doing? Do I create a loop of the ground in a precomp? Or is there an easier way to do this… Thanks for any input!
    Kevin Camp replied 11 years, 11 months ago 2 Members · 1 Reply
  • Kevin Camp
    October 21, 2014 at 11:49 pm
    motion also has an offset feature, though it’s less intuitively named ’tile center’.
    if you animate the tile center y component, you should be able to make it look like is moving, rather than animating the position property.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
