Activity › Forums › Maxon Cinema 4D › Infinite Background Problem
  • Tom Morton
    January 16, 2024 at 8:38 am
    I must admit I’m not 100% sure on what you’re asking – as I understand it, you want the background to be seen in the reflections, but it’s not – and you don’t want the floor to be seen in reflections but it is?
    I’ve opened up the project and it renders as I would expect tbh. I may be wrong but I had thought that compositing backgrounds don’t show in reflection because they don’t have an actual 3D position – they are floating without a reference point because they always remain at the back of the scene relative to the camera. It is as the name says, just for compositing.
    The floor is reflected in the sphere like it should – this is an actual object that is located in 3D space, so it can be referenced by all object by default are shown in reflections and in the view. And in the blank space not covered by the floor and background, you can see reflections of the HDRI.
    Please see screenshots, first one is default render which seems correct to the scene.
    If you don’t want to see the reflection of the floor, you need to select the compositing tag on the floor and uncheck “Seen by reflection” – please see second screenshot.
  • Tom Morton
    January 16, 2024 at 8:39 am
    If you want to use a background that is visible in reflections, you’re best off using a plane and adding the material to it, this will be located in 3D space and will be treated like a normal object.
  • Kouraib Abdmalek
    January 16, 2024 at 11:46 am
    I think the problem is in the reflection properties of the material because the standard properties in the material editor channels have changed in recent versions. I added the Fresnel effect to the Reflectance channel and got an appearance close to the result in the tutorial.
    I hope this helps you.
